Can I plaster over a plastic pipe and a plastic push fitting (equal T). I will cover it in Hemp Sleeving beforehand. Or does the plaster get into the inner workings of the pushfit connector and muck it up? What's best practice?
Pushfit fittings should not be covered over in plaster. The o ring needs to be energised for them to seal and that can involve a small amount of movement in the pipes.
If the pipes can't move the fraction required, you run the risk of a leak.
