shower pump feed- your thoughts
14 Jun 2011
Merseyside
Hi There
I am looking for comments/thoughts/advice.
I need to install a shower pump. Instructions say that the pump (twin impeller) hot and cold, must be fed by 22mm pipe. Currently I have two mixer showers fed from the storage tank by independent 15mm supply's direct from the cold water tank.
I was thinking I could take both these outlets (which will become obsolete) into a 22mm pipe to supply the pump instead of having to fit a new flange to the tank.
Your thoughts welcome.
Hi There
Decided to put a 22mm outlet on the tank. Thanks for your comments though!
