I had a job the other evening repairing a Boiler where an RCBO tripped in a customer’s house whilst I was out at the van.
The first I new about this was when the customer asked if I had turned off some of the electrics.
My initial thought was that although I had isolated boiler I may have allowed the N & E to touch so causing an imbalance at the RCBO.
However after a couple of minutes unsuccessfully trying to reset the RCBO I realised that as the connection between the boiler and the electrical supply was via a three pin plug which I had removed from the socket outlet,
So if understand things correctly I had not only switched off the boilers electrical supply but also totally isolated the circuitry of the appliance from the domestic wiring,
After trying to fathom out what was causing the Double D RCBO to fail for about an hour, I removed the ring main conductors from the RCBO (removed the load), and as the RCBO still would not reset I recommended the customer get an electrician.
I ran a temporary supply to the boiler via an extension lead.
Later the customer rang to say their electrician explained that not using the test button on the RCBO regularly had contributed to its demise.
I am not a proper Sparkie like what you lot are, so would appreciate any crumbs of info you might see fit to throw my way.
Tim
________________________________________
Tim
