TAKEN FROM BRITISH GYPSUM WEBSITE
Thistle Multi-Finish
This versatile final coat plaster provides good results on all suction backgrounds, and is therefore the best choice for plastering where both undercoats and board backgrounds are involved on the same job. It is also ideal for small jobs and patching.
Bag weight : 25kg
Approx coverage :10m2 (based on 2mm thickness)
Setting time 1.5 hours
Shelf life : 4month
Thistle Board Finish
The ideal final coat plaster for low-medium suction backgrounds such as plasterboard and Thistle Dri-Coat.
Nominal bag weight 25kg
Approx. coverage 10m2( based on 2mm thickness)
Approx. setting time 1.5hours
Shelf life 4month
Thistle Universal One Coat
For a variety of backgrounds. Suitable for application by hand or mechanical plastering machine.
Nominal bag weight25kg
Approx. coverage 2.5m2(based on 13mm thickness)
Approx. setting time 1.5-2 hours
Shelf life 4 month
Thistle Bonding Coat
Thistle Bonding Coat is an undercoat plaster ideal for smooth and low suction backgrounds, including:
Dense blocks
Concrete
Plasterboard
Backgrounds pre-treated with ThistleBond-it bonding agent
Thistle Bonding Coat is now even better, with a finer mix giving improved workability, especially being:
Easier to spread
Smoother
Easier to rule and darby
Approx. coverage 2.75m2(based on 11mm thickness)
Approx. setting time 1.5-2hours
Shelf life 4 month
Thistle Hardwall
An undercoat plaster with high impact resistance and quicker drying surface. Suitable for application by hand or mechanical plastering machine to most masonry backgrounds.
Approx. coverage 3m2(based on 11mm thickness)
Shelf life 4month
Thistle Tough Coat
An undercoat plaster with high coverage and good impact resistance. Suitable for application by hand or mechanical plastering machine to most masonry backgrounds.
Shelf life 4month
Thistle Browning
An undercoat plaster for solid backgrounds of moderate suction with an adequate mechanical key.
Approx. coverage 3.5m2 (based on 11mm thickness)
Approx. setting time1.5-2hours
Shelf life 4 month
Bag weight : 25kg
Shelf life : 4month
Shelf life 4month
Shelf life 4 month
Dense blocks
Concrete
Plasterboard
Easier to spread
Smoother
Shelf life 4 month
Thistle Hardwall
Shelf life 4month
Thistle Tough Coat
Shelf life 4month
Thistle Browning
Shelf life 4 month
