J
jchapman9
I have an inline fan in the loft operated by a movement sensor overlooking the shower. I found humidity sensors gave up after a while. The movement sensor has the timer function built into it. As this setup wasn't doing a very good job of extracting, I installed a Manrose Showerlite directly over the shower, a more powerful fan, and a Y piece linking to the original extractor vent.
Problem is the Showerlite needs the fan on when the lights are on to dissipate heat. As there is plenty of light in the bathroom, the lights aren't needed all the time. Nor do I really want the fan to stay on for 20 mins if someone just pops into the bathroom to look at a spot or something.
What I would like to do is insert a relay between fan, lights and sensor such that by default the fan is operated by the motion sensor using the NC connection, but if the lights are turned on the relay switches to the NO connection and the fan is switched on. When the lights go off, the fan stops unless the sensor has been triggered. At the moment, the fan is driven by the sensor which has a 2 pole FCU isolating it. I imagine I would need a separate FCU isolating the fan itself and maybe another for the relay. Ideally, a mains relay with mains coil would be easiest.
Is there a proprietary solution for this or any suggestions re choice of relay etc?
Thanks.
Thanks.
