I'm installing a Saniflo Sanislim macerator -
I'm suprised the main waste outlet is only 22mm diameter ..
Looking at the installation guide its a bit ambigous if I should route this into a 32mm (or 40mm) pipe once it goes 'horizontal' at the top of the vertical ...
Is this the case ... or will running 22mm pipe all the way out to my drain be OK?
Or would it work better if I used 32mm pipe straight out from the unit?
