No, but if all the word connotes for you is an obsolete paint system, that would explain much
(The reason I asked about your first language was because your use of English syntax is highly interesting and unusual at times). It would be productive to analyse it, in fact.
Yes, you did. Your use of the imperfect past tense ['There was...'] and the postmodifying adverbial 'many years back' definitely conveyed that impression (intentionally or otherwise) .
If it were still used today, you would presumably have said 'There is a paint system called Syntax'.
Not really, it was termed as Syntax many years ago, yet this system however is available today though under a different name with a more refined binder. And guess what,I sure ain't going to tell you.
Dull as this non-conversation has been, I've found out what I needed to know...so I'll bid you good night. Try to wake up tomorrow in a more sociable mood!
The salts are what is called the early formation of efflorescence as already pointed out by MrH, the important thing to remember here is in no way dampen or wet the surface.
Using a dry rag or a broad edged scraper remove the infestation and cover the entire area with an alkali resisting primer, again mentioned by MrH
Thanks for the quick reply Dec.
Before I go ahead and do that is there anything I can do to ensure that this would work? Something to look out for maybe or a technique involved?
When you apply the primer make sure that you fully cover the infestation and feather your primer out to a point where your brush is void of paint, this will both ensure that the area is both fully covered, and elminate any sanding of the edges in order to establish a uniform finish.
