Need your help, kids are cold!
14 Apr 2012
Need your help from the pros around here..
We have a glowworm 30BF boiler, now the ignition light is on, but when we turn the dial to ignite the boiler for hot water or heating nothing happens? I spoke to my brother in law and he mentioned that it needs a new diverter valve and they are simple to fit.
I have been to a few places and when i tell them that i need a diverter valve they give me astrange look and don’t know what I’m talking about lol.
Can anyone please help? is it possible to reset these boilers some how or is it time to call in a plumber.
try a 3port valve the silver small box in your cylinder cupboard, or the pcb on these boilers go aswell !!
Thanks mate, but what is that? I see a silver box when i take the bottom section off but its all enclosed.
thats maybe because your boiler doesn't have one
your system probably has one of these
IoQnhC9fDwMhkh0gs93agggjVaoesTKQka6ifDv88yEnWWvIOz0Qi06sdypsXhlnGYRvNLRoPeeAwy81o3cuVL1IJMt3-2IMU233HSm3AYmvLHjqA67kgZeL0D3VGBpHf6A4H0tXdfkusiTQTty1NL2KyO7oFOc_Y278SVY9wHHvTpQfOIO6SDXsK989fLRY
Or a couple of these
ca_beWpu3DkZm3dBHmwrugandrCZOureiacoVG78hmCurHBXvul4_YuHyLdWQq4o7ocUQ_TMHwFLxDKud9CT4WArpsIj0OKTdZV4Tr-nCSFg53k-u2RqKAdXq5KKI4JSffMb9iemUIlZtvZVfBwxvE-h1A0SEnbBfV1Mqt9qE07GpkltshsrC6-GEGAbrTsT
but since you don't have either hotwater or central heating then its likely to be a problem with the boiler or a wiring issue anyway
Matt
ummmmm is it me or does the said boiler have not diverter valve ? its not a combi its a heat source only boiler ,
the silver box is the same as the pictures above and are situated somewhere on your heating system , normally in your cylinder cupboard, there is a manual lever that can be pushed to the open position
the other thing it could be is the circit board , as the boiler is saying its ignited yet its not actually alight
by this, do you mean the pilot light, (small flame through viewing window)
The thermostat dial?
cant imagine why he said that :shock:
Perhaps the brother in law needs the said valve..so, OP buys the valve, then declares it is not the item that needs replacing when the brother in law smartly steps in and takes the valve.. :D
You have a dirty mind , has anyone ever told you that? :wink:
only a gentleman from north of the border would be so frugal. :wink:
