Hi - we're looking to add a supply to our new log cabin / office in our back garden (about 15m away from the CU). We anticipate it will have 1 PC, a 2kw electric heater, a small fridge and some basic lighting.
We intend to take a 6mm T&E cable from its own connection in the CU in the house (non RCD side), through plastic conduit mounted along the house wall, then buried underground (still in 20mm conduit, under concrete slabs) to some sort of local protection / CU unit in the cabin.
There is already a supply and conduit running above windows & doors along most of the front of the house which simply feeds an outside light at the front door. My main question is, would it be OK to replace that existing cable with the new 6mm T&E and take a connection off it to power the outside light, on its way to the cabin? Or should we replace the existing conduit with something wide enough to take the front door light cable and also the new cable to the cabin?
Would also like some advice about how to terminate the cable and distribute the power when it reaches the cabin?
Cheers
Cheers
