vaillant turbomax vuw242e / 282e no hot water
16 Apr 2012
Northamptonshire
hi, i have hot for radiators but not through taps, i took out diaphram and cleaned which was ok, manual says it must be micro switch as when i press the metal rod with my hand and push the switch down it fires up, although i still have no hot water when i do this. what should i buy to fix this?, many thanks
Perhaps you need to buy a boiler engineer?
There are many other aspects to a combi giving hot water than just the diaphragm!
i will need to try that one cleaning a diaphragm :roll: why go to all that trouble and not change it they are only about a fiver.
i could get a boiler engineer who could easily rip me off if i dont knowthe prblem myself
the manual says to change the dhw micro switch
yeh, i could have changed the diaphram with one i had sitting about like every other household lol :P i could have spelt it right but am busy at work and not just giving out naff info cos im bored at home without a life
Common sense you order the bit before you strip it down after asking advise on what the cure is.
Pray tell where you gained the info that cleaning a diaphragm would cure a boiler fault .
And it doesnt take a rocket scientist to work out it cannot be the microswitch if it fires when you manually press it :roll:
not really tbh, if it aint working what does what i do matter. i want info not snotty nosed advise. stay off my topic if you cant help please.
