Hi all, I'm a network tech and my Dad is a retired electrical fitter so a bit out of date. I have a sparky I can ask but wanted some comments first.
Ok, my (new to me) 70s build flat had a periodic inspection as part of my purchase. It needed a new fuse board and RCD as it had a power shower fitted and had not been updated. I have the report, it shows 6mm cable for a "Cooker" circuit and 32amp fuse. Should this be 45Amp?
There is a circuit for the kitchen sockets which also seems to do the living room sockets!
The hob is running from a cooker switch above the hob.
The oven (single), washing machine (when i get one!) are all running from a couple of doubles UNDER the sink (!). I am replacing the hob and oven, the oven is going to be a 16Amp rated hard wired model (Bosh).
I want a pukka setup, so what do I need to do and what does my sparky need to do under Part P?? Is there anything my Dad can do? Should we blank of the hob switch and put a switch in elsewhere or can we run a feed from the existing hob switch to the cooker?
To comply with Park P, should he issue a certificate cos he put in an extractor fan in the kitchen and bathroom and I did'nt even get a receipt? He said the work was to spec and is covered under my inspection report.
Any suggestions on what I should get done?
Thanks.
Thanks.
