From that, anyone would believe the people who've replied have a responsibility to you.
I think it's you, Namsag, who should read Simond's example more carefully!Simond no not on drugs try reading up on what is required from Central heating .Then after that try reading up on your 9.5 degree statement![]()
Sorry, Mr N, but it's you who needs the education.No that is not how it works as well you should know .
You seem to struggle with what is required to get a room up to a required temp in the proper time . I am not here to educate you I don't have the time. try using google more selectively
So using your logic, Namsag, a 5 kw boiler would take 6 hours to heat this house from outside temp of -2c.........
Yep, thought so. ha ha.
Heatloss calcs for MCS accredited systems now have to use CIBSE guide B. This is generally acknowleged to be the most accurate method and has to be used for FiT.
Suggest you shell out £100 for a copy.
Ps: to stroppy OP, the best one is the Vaillant new mkII ecotec 6 series, but size it scientifically, rather than eyeballing it.
