All domestic boilers now are both condensing AND modulating!
Are they?
Heat pumps aren't modulating though.
thats why you use a buffer tank with GSHP....and from there you need a compensated mixing valve...
delta T, the IPHE mag the other day published a report about UFH, the top rating being for screed floors the lowest for UFH in wood floors..
would you like a copy?
I'm trying to clear confusion for the benefit of others as well as your good self.
It is simply that the best way to connect and control underfloor heating to a condensing boiler is direct to the boiler, not via a thermal store and not via an external pump, blending valve, timer or thermostat.
System reset - Flow temperature reset by modulating a mixing valve or pump set; no corresponding UK term
Do you controlled temperature circuits onetap![]()
Not at all Onetap, just asking whether you mean controlled temperature circuits![]()
A boiler will be fully condensing when the flow temperature is below 55C. It will be partially condensing with the return below 55C.
