Hello,
I recently bought a celling fan (without light) and installed it in the bedroom, replacing the main ceiling light. The bedroom has two way switches, so now, the fan works perfectly well and we're able to turn it on and off from either switch (just as you could the light). The only issue is, it obviously on full speed or off. So i bought a Expelair WAC1 controller.
According to the installation guide, the controller inputs Live and Neutral, and outputs Live and Neutral. I don't think I have access to neutral in either switch box. The wires I have coming from the wall are....
At switch point 1 - A yellow with a red sleeve.
A blue with a red sleeve.
A red
The yellow goes to common and the red and blue go to L1 and L2 on the light switch.
At switch point 2 - A yellow with a red sleeve.
2 blues with red sleeve.
2 reds
The yellow goes to common and the reds / blues goto L1, L2 on the light switch.
Does anyone know how to proceed? Am I correct thay none of these are neutral? If so, how can I get a neutral to the controller then from the controller to the fan?
Thanks for reading....
A red
2 reds
