Our dishwasher is playing up. It is not heating the water and the cycle goes on and on and on.
From what I can find it may be the instant hot water unit or possibly the temperature sensor.
I have taken the bottom off and have stuck a multimeter on either end of what looks like the element sticking out the end of the heating unit. No buzz. Does that mean its knackered? or is there some sort of internal switch.
I cant find the temp sensor to check. Any idea where that is?
Also, if I need to remove the heater unit to change it how does it come out. The 3 screws holding it in place seem ok but it is the connection to the pump that I cant work out. There is a metal clip on the pump end of the short rubber tube which I cant work out how to undo.
The heating unit looks like this:
http://www.ransomspares.co.uk/parts/dishwashers/bosch/heater-element/57117.htm?m=156440#
With much thanks.
With much thanks.
