Hello,
I had success here in the past in fixing my boiler so need help again:
http://www.diynot.com/forums/viewtopic.php?t=157694
My mini C28 combi boiler recently has another problem in which the ignition cuts out and the boiler gets stuck in a loop trying to ignite.
It seems to happen much quicker during hot water use rather than central heating, although i have noticed the problem occurs with the heating eventually too.
Hot Water operation after around 2-15 mins
Heating after around 30 minutes
If I switch the system off for a while it repeats the process after "cooling" down.
There is enough gas and water pressure is at 1.5 cold and 2 heated.
I can hear the pump start and the clicking of microswitch, I have not checked to see if fan is spinning but I imagine it is as heating has been running for 25 mins as I write this on a heating test.
But as soon as a I try hot water running it jumps to the problem.
The diagnostic lights show the fault for "lack of burner ignition" once the boiler works out it has a fault when it goes into the ignition loop with no spark. It is a whiring sound start and stop, start stop etc
Is this a fault with pcb 2 board on the right?
I have photos below of the front and back which looks like some heat damage to the resistors, so when they heat up they are breaking the circuit and causing the sequence on the board to fail.
My model number is posted as below:
I hope that you can help.
Many thanks in advance
