Hi
Having read the wiki on electricals and part p, I think that I can undertake this work myself, but I'd like to be sure if someone is happy to confirm.
I currently have a small downstairs loo including a sink. I am going to remove the toilet and sink, and leave drainage and pipes in place for a washing machine connection. I intend to seal the soil pipe from the toilet and leave the waste from the sink for the washing machine drain.
I also want to put a freezer in this small room, and as such with the both items I will need to put in 2 sockets - minimum 1x1g, and 1x2g.
I have a radial circuit that goes out through the window to a cupboard providing a 2g socket in there which is used for the tumble dryer - the cupboard is fully enclosed.
By adding 2 sockets to this radial circuit I believe that it would be classed as minor work, and therefore not notifiable, and as the toilet and sink have been removed, no longer a bathroom?
The current radial circuit is running off an existing mcb accommodating sockets, and though this was ok at the time, I wonder if I should put in an extra MCB and make the circuit into a ring rather than radial? If this was the case, would the job then become notifiable? The ring has 15 gangs (a mix of 1 and 2 gang sockets) and a b32 MCB, with the radial coming off the same MCB.
Many thanks in anticipation for your help.
Dan T.
Dan T.
