Morning all,
My laminate has been down in my living room for 2 years.
It was laid ontop on a foam underlay with a vapour proof barrier in it.
The last few month though some of the joints in the centre of the room started to blow, and looked a darker colour, so auto thought moisture - blamed the mrs at first for mopping it!!!
Got to a point where i decided to tale it up last night and immediately saw the issue.
The concrete sub floor was soaked!!
It had penetrated the joints of the underlay but has also seeped through the underlay onto the boards!
When peeling the underlay back the floor looked like a sweaty surface.
The moisture is brown and really sticky, and of course smells damp!
The floor is like it, spread from the inside, out and stops at the skirting boards, where the edges are dry (presumably as it airs under the boards)
Also there is a different part of concrete in front of the chimney breat and that is bone dry and water hasnt penetrated that part.
The subfloor is fed by an air brick on the outside which appears clear.
What would appear to be the issue?
Can upload pics if needed.
**edit - i dont have any leakind CH pipes as my sealed system doesnt loose presure.
Also i dont believe that a mains water pipe runs under the living room floor looking at the meter points of mine and next doors house in the path.
