double check valve - noise & screw
Could he not get rid of the non return entirely or am I missing sOmething.
replace with a single check :idea: . I`m not sure why doubles are used there :? I thought they were for wholesome water backflow protection - on hoses etc.
I don't think I will find a single valve of the same length as double one. And I do not want to cut/extend the pipes so I think I will stick to a new double valve... Though, got a bathroom renovation going on just now so this will have to wait for a few more days.
Anyway, thanks a lot for you answers everyone!
Whilst the test point can be used to drain the valve ( if fitted facing down ! ) the real point as Chris says is as a test point to comply with the water regulations in many applications when a double check is required.
DIA should have remembered that.
I would always fit a NRV on the hot OUTPUT from the boiler and not on the inlet. That can prevent damage within the boiler by expansion.
You can convert a double into a single by removing one plunger ( or by withdrawing its spring ).
Tony
I thought fitting NRV on OUTPUT from boiler is not recommended anymore therefore on the INPUT?
Why did you think that?
I will argue that it increases the likelyhood of damage inside the boiler!
Tony
I agree.. therefore the need for a mini expansion tank on DHW (that I do not actually have ;)
To be honest, I do not remember just now where I found the recommendation on inlet NRV. But I agree it would make more sense to have it on the outlet, though I'm just an DIY person not a pro...
But, my boiler installation instruction do say that in some circumstances NRV might be required and it should be fitted on inlet... again, there is no justification of it :D
Most plumbers would fit it on the inlet.
But then most plumbers dont think about the technicalities ( or in many cases even have the basic scientific knowedge as they left school at 16 without taking/passing any science A levels ).
Tony
