I don't think I will find a single valve of the same length as double one. And I do not want to cut/extend the pipes so I think I will stick to a new double valve... Though, got a bathroom renovation going on just now so this will have to wait for a few more days.
Whilst the test point can be used to drain the valve ( if fitted facing down ! ) the real point as Chris says is as a test point to comply with the water regulations in many applications when a double check is required.
DIA should have remembered that.
I would always fit a NRV on the hot OUTPUT from the boiler and not on the inlet. That can prevent damage within the boiler by expansion.
You can convert a double into a single by removing one plunger ( or by withdrawing its spring ).
I agree.. therefore the need for a mini expansion tank on DHW (that I do not actually have
To be honest, I do not remember just now where I found the recommendation on inlet NRV. But I agree it would make more sense to have it on the outlet, though I'm just an DIY person not a pro...
But, my boiler installation instruction do say that in some circumstances NRV might be required and it should be fitted on inlet... again, there is no justification of it
But then most plumbers dont think about the technicalities ( or in many cases even have the basic scientific knowedge as they left school at 16 without taking/passing any science A levels ).
