Hi Folks,
I am totally new to roof repair but I'd like to give it a go. I own a top floor flat that is a loft conversion so it has a pitched roof and a felt flat roof. See the attached photo. The red square represents my flat and the oval is where the problem is.
There is water coming through the roof somewhere right where the wall meets the ceiling just above the window. The fascia boards weren't in the best condition but have since been replaced. Nothing else was done when the boards were replaced. I replaced the silicone sealant at the top of the window (inside) as it looked like water was coming through here. This seemed to stop the problem for a while. Then after a few weeks I noticed water damage on the ceiling right where the wall meets it.
I am happy enough to go out onto the roof (with harness and climbing equipment) but am worried that I won't see the problem very easily. Will I have to remove the fascia boards to put some Acrypol or Thomsons Roof seal under them? is it possible that the water is getting in further up the roof but running all the way to the end of it before it is becoming apparent? I will try to post some photos up of the roof.
Could the problem be where the felt terminates which is presumably under the fascia boards?
Thanks for your help,
Jonny
Jonny
