Light fittings vs insulation
6 Nov 2011
Hertfordshire
I've just replaced a plasterboard ceiling and stuffed insulation across the whole room.
I hadn't considered leaving air flow for the light fittings - what's a sufficient space to leave? A fire isn't desirable.
I can't bear taking sections back down so hope drilling a hole through the boards then tearing enough insulation for the light fitting is sufficient.
What type of lights?
Is the cable resting on or in the insulation?
Its not just lights, cables can also be affected by burying in insulation
Downlights come with instructions that detail clearances on all sides and above the fitting.
Approx 100mm is normal, so you'll have to pull a lot out.
What a shame to have created that nice cozy layer, and the reduction to sound transmission between the floors, only to wreck it by turning the ceiling into swiss cheese.
Each to his own, I suppose.
Re the wiring, I hope that this is clipped closely to the joists? As mentioned above by rocky, the cable will not like being buried in insulation.
Ban
I have posted your links in another thread.
Perhaps they could go in the Wiki if they're not already?
Is the 2007 article in the wiki the one you link to here?
The other two I cannot find in the wiki.
I have from some aurora downlights that are "insulation covered" downlights, looks like they are about £20 each in the net. I am going to ask my electrician if he can fit those for me.
