Hi all
I plan on having a 16A socket installed for my APC Switched Rack PDU (AP7952)
Incase anyone is wondering its basically a huge extension lead where you can turn individual sockets off remotely..
http://www.apc.com/resource/include/techspec_index.cfm?base_sku=ap7952
Please note that I will be getting a qualified electrician out to install this (although I may run the cable for them to keep costs down) just like to do my research first!
At the moment where this is living is a double 13a socket, I am assuming I need to have a new run of cable to the consumer unit with a dedicated MCB to power this unit (distance of cable to run is about 8m)
Also the unit which I will be plugging in has a IEC-320 C20 connector (looks like http://buysg.com/images/APC_AP9877_1.jpg) I was wondering if its more appropriate to change this to a 16A commando plug? The cable coming out the unit is 1.5mm2
A socket and plug are about £5 each at screwfix
As far as I am aware these commando plugs don't have fuses, will the MCB (depending on which one is installed) have any overload protection?
Nick
Nick
