- Joined
- 7 Dec 2010
- Messages
- 38
- Reaction score
- 8
- Country
Hi folks,
I have a single storey sandstone cottage, around 100 years old and am looking to fit a woodburner.
Decided to open up the wall on the weekend, to see what i've got. The original opening is large 1m wide by 1m tall and i suspect it had a range of some sort originally. Later on it has been fitted with a fireplace, and then about 10 years ago the front of that was taken away and plasterboarded over.
The original sandstone opening looks in good enough condition and appears to be bearing the weight of the wall above as you would expect. The red brick infil was covered with firebricks before i took the pictures. Above the red brick a throat has been formed for the fireplace with sheet metal and cement has been poured in up to the underside of the sandstone lintel.
Peeking up the chimney it appears that nothing relating to the fireplace is load bearing. Obviously the first job is to clear all of this out and expose the opening.
Can anyone see any issues with this?
Some more pics here:
Pic2
Pic3
Pic4
Pic5
In this pic, you can see round the original sandstone wall behind the brick.
Pic5
I still have to check under the floor to see what remains of a hearth, if anything.
I'd like to install a Morso Squirrel, and am thinking about brick lining the opening down to resize the opening to a more pleasing proportion. This would also give me a sound base to fit the register plate.
Thanks for your help,
Pic2
Pic3
Pic4
Pic5
Pic5
