Hey all, sorry this is my first post but a bit stuck here really as I'm having a problem with my Worcester 28i Junior combi boiler.
It has been working ok since we moved in a year a go apart from a rad once had a few cold spots, suspected dirt in the system. It hasn't been run other than hot water since Apr 12.
I decided today I would drain the system as needed to fit a new vent plug on my daughters radiator and thought I would drain the system and fill with Sentinel x800 to clean it all as no record or cleaning or new inhibitor since 2004 (installation date). My plan was to then flush it through in a couple weeks and fill back up with Sentinal x100 inhibitor.
Anyway drained the system today, apart from the water in 2 rads downstairs as no drain points on the bottom. Poured in the Sentinel x800 and fitted my daughters new vent plug. Switched the boiler back on, used the filling loop to pressurise to a little over 1 bar and bled the rads. Pressure dropped as expected and topped back up to a little over 1 bar. Now I ran the heating and within 20mins the pressure was up to 2.5bar so I quickly turned it off (before the PRV if that's the correct term dealt with the over pressure). I let the system cool and it dropped back to 1 bar. So turned it on again and within 20mins back to 2.5bar so turned it off again.
Read on here about the expansion vessel, so once the system was cooled down, released the pressure in the system and took a reading on the expansion vessel of 0.45 bar (no water was being released). Topped that back to 0.95 bar and filled the system again to 1.25 bar. Bled the rads and turned on the heating. Again within 20mins the pressure rose to 2.5 bar so turned it off again.
Now I'm scratching my head really?! I don't really know what to do or check...do I just call a plumber in the week?
Sorry for the long post but thought that all the info may help. I'm a pretty competent person but don't know the next move?!
