Good Morning wonder if someone can help....
We currently have an Economy 7 meter but I am looking to swap this for a standard rate meter as we only have one storage heater (in the converted loft) and GCH.
I called NPower and they said "can swap it over without replacing but if the storage heater is wired into the night rate then it will not work"
So how do I check if it is or not?
I have checked the meter and it has 4 tails labeled N, N ,L, L.
The meter itself states Rate 1 N, Rate 4 L, both these lead to the fuse board.
The storage heater is connected to a fuse and a timer, removing the wiring cover from the timer and applying an electritions screwdriver shows voltage at all times (not just at time of the night rates)
The heater has a seperate fuse in the fuse box also.
I have attached some pictures, sorry for the poor quality on some.
http://www.diynot.com/network/muddytoast/albums/
