Hi
I've a Ravenheat HE85T boiler, very similar to CSI85T model.
Recently, the boiler has been constantly re-lighting on both CH and DHW and sometimes the red (overheat) light comes on. I checked the thermisters, they were OK. Replaced the DHW (wet pocket type) with a known good thermister as I thought it might be some hard water damage, still same problem.
The pump works OK, the fan can be heard to go high speed.
The water gets hot, then lukewarm, then hold or cold again before the boiler starts refiring every few seconds.
I replaced my existing fan PCB (which fails every year on boiler) FROM:
http://www.ebay.co.uk/itm/Ravenheat...ooling_Air&hash=item2575e9e5cc#ht_1086wt_1456
TO:
http://www.ebay.co.uk/itm/Ravenheat...Cooling_Air&hash=item1c2ba9712d#ht_958wt_1397
It worked OK for a day before going to the same state as described above. As you can see the new one has lot more electronics on its circuit board compared to my previous one. However the part number 0012CIR06010/0 is exactly the same. Does this matter?
My worst fear is ignition control board (main PCB) and I hope that never comes true..
I hope I get some quick replies and many thanks in advance for that..
TO:
