Boiler location
13 Feb 2006
Tyne and Wear
We are going to replace our old 'back boiler" with a conventional wall mounted combi.
The only logical location on an outside wall is on the bathroom wall. This is a bungalow and the wall faces north, straight in line with the prevailing wind. Would this be a problem for the flue
No problem as far as flue and wind is concerned
If there is another location you would prefer, you could do a vertical flue upthrough the roof?
You would need to consider the condense ( can be pumped) and the pressure relief , which some manufactures do an up and over, like, Valliant, potterton/ baxi
Just an idea
Terry, where does it say that? is the in the manual or some other source?
First I heard of them was at BG, ive fitted a few.
Phone there tech and they will give you a part number, I don't know why they don't make them more readily available.
It is cosher though :wink:
