Emergency: no heating or hot water!
21 Dec 2011
Kent
Hello - hoping someone can help me!
I have a Glowworm Ultimate boiler which has worked fine until 2 weeks ago. Now I have no hot water or heating.
The boiler appears to be working - I.e. the pilot light is on. But it doesn't matter what combination I have (hot water only, central heating only or mixed) - there is no hot water anywhere.
Immersion works fine so there is water in the system.
Any suggestions?
The hot water you get from the taps is not the same water as in the boiler and CH system, they are kept seperate. Immersion working and HW at the taps is not an indication of water in the CH system. :wink:
Chances are its an electrical problem. Is the time clock working, and if so, are you able to test for power at the boiler?
The boiler feeds both the hot water cylinder and the central heating though? Neither work. The clock works fine ... the boiler works fine.
The boiler heats the contents of the cylinder via a heat exchanger (usually a coil of copper tube) within the cylinder, thus keeping the water in the cylinder supplying the hot taps, and the water in the boiler/rads/etc seperate. (Boiler/CH system is usually fed from a seperate smaller cistern in the loft).
Pilot light indicates there is gas to the boiler, but for the boiler to fire and heat the water it needs a power supply when there is a call for heat. Are you able to test for mains voltage at the boiler?
