Hi
In Potterton Prima 80F on the bottom of the Unit situated the COMBUSTION CHAMBER and above it is the HEAT EXCHANGER and on top of this is the FAN and to it connected at the summit above top the FLUE ELBOW to leave the system to the out.
Now I think it is negative pressure unit as the Fan is after the combustion chamber sucks out .
Here is the Manual: http://www.partsarena.co.uk/baxi/System/DATA/Dx/DS1/installation/2072/I01-2072/I01-2072.htm
Does any body can help me understand/identify with regard to if it is positive pressure or negative pressure boiler? or this Positive & Negative pressure does not apply to an open vented boilers?.
My understanding is the seal of a unit is more important in a positive pressure boiler.
The boiler is situated in the outside garage with the Flue goes out through the garage wall.
