Hello!
I've just finished flooring my loft and I've installed a double strip light currently just wired to a plug and into an extension I run to a wall socket when the hatch is open. Now I want to add a spur from one of my upstairs lights to the strip light so I don't need to run the extension. I've done wall socket spurs before but this is my first lighting spur...
As far as I can tell I have the circuit detailed at the top of this page (Method 1), as I see no junction boxes in my loft and each rose only appears to have one cable running to it (house was built 2008 and we're in Scotland, if that tends towards a certain circuit style?):
http://www.ultimatehandyman.co.uk/lighting_circuits.htm
Am I right in thinking I can simply take the feed directly from an existing ceiling rose to my new switch and then on to the strip light? (I'm confident on wiring the switch and strip light, I'm just not 100% sure if I'm safe to take the feed from an existing ceiling rose?). The light I'm planning on taking a feed from is a single light in a bedroom with only one switch attached...
Many thanks for your time,
-Ross
-Ross
