Ideal Response 120 Combi Loud Rumbling
Funny you say that. the Ideal chap said 'BG don't know there is an adjuster on there'. He adjusted it himself as a temporary measure. Unfortunately he must have adjusted it the wrong way since the rumbling was happeneing every 10 minutes after he left. Anyway. All sorted for now.
You can adjust the response gas valve but only on low burner pressure which as it is done through thermistor is near impossible as it will jump about. UNLESS that is you have a splitter which goes onto the pcb instead of the molex from the thermistors.
This has a big switch with high and low on it and allows you to adjust the low setting properly.
As Agile says unless you have the equipment done do it as it is near impossible to do.!
