I've removed carpet and underlay in a bathroom, in prep to fit sheet vinyl, but now I have noticed a lot more noise/echoing. I guess this is not surprising as carpet is a good sound insulator. It's a suspended floor on sheets of chipboard.
Is there anything I can use as sound/heat insulation on top of the chip board before I lay the vinyl? I have some 6mm ply, only recommended by the vinyl comp to remove imperections etc, but if there was something I could fit as a an insulator between the chipboard and ply it would be good. Otherwise I am thinking of a lot thicker ply, maybe 22mm if I can't find an insulator.
