Fein Mulimaster
17 Dec 2012
Aberdeen
I making 3 wooden cupboards for my daughter and her boyfriend's new house. Im looking at the Fein multimaster limited edition to help. Does anyone have any experience with this item and could you let me know if this is a good deal?
http://www.websterpowerproducts.co....rded-tools/multi-tools/fein-fmm250q-le-detail
I have order from them before and they are reliable but I don't wont to phone there sales line because they will not tell me any flaws with the machine and just try to sell even if its not right for me.
Many Thanks in advance.
What exactly are you hoping it will do for you?
Hi.
The wood is quite old and has a few screws that I would need to cut and sand (I will prob need to sand the whole unit), sawing and joints.
I know the multimaster has the blades for this as it is described but have never used the machine before and need som advice.
Thanks for your reply.
Hi.
From your fairly vague description I would say the multimaster would be totally unsuitable.
Can you please stop here, start again with a fresh post and just get to the red meat of the issue
Sorry, this is thr first time I have undertook any DIY projects so sorry for being vauge but I will try to explain.
Basically I have no tools (ie saws, sanders etc). I have a stack of old wood that I was looking to turn into cupboards. The wood is very old and looks like it will need a bit of work. There is a large number nails in the wood that just wont come out and will need to be cut/sawed, all the wood will need to be sanded and I will need to cut the wood to size.
Instead of going out to buy all the tools I need I was told that I should check out the fein multimaster Limited Edition as it does all these jobs. I was just wondering if anyone had any experience of using it for any of the jobs I will need it for and if it is any good.
PS. Also if the deal I linked to was good or if there is a better one anyone knows of
The Fein is designed for small cut off actions like removing timber in situ, if you are using second hand timber all nails and screw will need removing, you can't plane down or sand to a reasonable standard with metal in the way.
This isn't the right tool for you....to start with, if the planks are very rough then you'll need a belt sander to get through the top layers of dirt / paint etc. After that maybe a 1/4 sheet orbital sander would suffice.
To cut the planks to length either buy a quality hand saw, bench hook and try square or go for a chop saw....one with a sliding arm would be better.
A smoothing plane is essential too.
To glue planks side to side you'll need some sash cramps, to cut housing joints or rebates you'll need quality chisels and a tenon saw (or a router).
The list can be just about endless, and it depends how far you want to go, and how much you want to spend!
John :)
Hi woody
first the Fein multy tool, a great bit of kit for the trade ,If your a weekend chippie I would say they are overspeced for your use,Bosch do one a lot cheaper, but it it sounds like you could redirectyour funds to more usefull kit:chop saw, sander,etc.........
second:reclaimed timber is a hell of a challenge for all the obvious reasons, and conclude its the look you are going for and it can be achieved.
Post some designs and we can take it a bit further
Hi woody
[/quote]
Not a week-end chippie, never done anything before, so think cupboards are likely to be too much.
Not a week-end chippie, never done anything before, so think cupboards are likely to be too much.[/quote]
you don't have to be a chippie at trhe weekend's ,you just have to want to do it ,then try hard with some technical help.
you don't have to be a chippie at trhe weekend's ,you just have to want to do it ,then try hard with some technical help.[/quote]
