I am looking for a recommendation on a way to control my heating system
I currently have a large tenanted property
There are 2 glow worm 30cxi combi boilers, each being controlled by a mechanical clock fitted on each boiler,
unfortunately on both boilers, these clocks have stopped functioning when switched to 'timer mode'.
One boiler controls the ground floor water and heating and a room thermostat is on that floor
The second boiler controls the first and second floor and has a seperate room thermostat on the first floor.
All radiators have TRV's also.
Ideally the tenants should be able to turn the boilers on or off easily and a a function where the heating comes on for an hour would be great (like a boost function), because i suspect they might just turn the heating on
and then not bother to turn it off. so the property is heated even when they are out.
The clocks are expensive to replace, so I thought it would be better to invest in something that gives the tenants easier control, like replacing the thermostats with Programmable Room Thermostats. If thats the best
solution, then can anyone recommend any.
Also, i opened up one of the clocks, and there was a loose spring, and where it was attached to had snapped. So i believe thats why it doesn't work.
