Silicone sink fixing
7 Feb 2010
When I fitted the pedestal basin to a tiled wall in our new shower room, I fixed the basin to the wall with a goodly splurge of silicone, to save drilling. Solid as a rock.
However, subsequent requirements entailed moving the loo and the basin. I was anticipating a fight with the silicone and I was right, as the basin would not budge however I tried to pull or twist it from the wall, and there was insufficient gap to get a blade in, to slice through the silicone.
In the end I used a trolley jack and a piece of wood to lift the front of the basin, which worked, and it came away. Taking a dozen tiles with it.
I have just finished grouting a dozen replacement tiles... Fortunately I still had some spares.
At least it saves having to clean the silicone from the wall. Although I do have to remove the old tiles, that remain firmly stuck to the back of the basin...
Cheers
Richard
Excellent idea.
Mine is stuck to the wall like this too (it was done before I got the house) and I have removed the pedestal underneath before but left the sink there.
I will remember about the jack when I need to remove mine.
Should have tried a cheese wire, will go where a blade cannot.
I think the trick is probably to ensure that the sink is 5mm or so away from the wall, so that you can get a blade/cheese wire/wire saw through the silicone if you need to remove the sink. And to use less silicone than I did :rolleyes:
Cheers
Richard
Read this post on the Saturday & chuckled. On the Sunday decided to lay some lino in the bathroom. Took the pedestal out from under the sink as the old lino went under it & the sink has screws holding it to wall. Didn't think too much more about it. Rolled out new lino & tried to kick it into shape/line along the wall. Grabbed the sink to steady myself & the sink pulls away from wall! Luckily the waste held most of it!
Fixed back with a lot of silicon & bigger screws (& the pedestal for good measures)
A close one!
Sorry if this upsets anyone but fixing a basin with silicon is nothing other than a bodge.
I don't think that anyone here has said otherwise :)
Sometimes a bodge is the only way though.
For a proper bodge you do need to use clear sanitary silicone. The white stuff contains fillers and doesn't have anything like the grip.
Cheers
Richard
As a postscript, I've now fixed the basin in its new location using the proper fixings, and not a trace of silicone. Much nicer.
Cheers
Richard
I'll take this opportunity to say that I don't fix sinks to the wall with silicone any more. It's a horrible thing to do.
Cheers
Richard
In my old house, the plaster was coming away from the wall a nd it made sense to fix the plaster to the sink with silicon :LOL: :LOL:
Yeah, don't use silicone as it obviously does not work. ;)
Use no more nails instead :) :) :)
This is actually quite funny to me...my bathroom sink was leaking at the waste pipe join and i needed to take the pedestal out to tighten things up,....it was then that i realised the sink was siliconed to the wall
