Ok this is my first post on here and im new today.
Basically I moved in to my home in november 2011 and we finally got to a stage where we can start doing things to the home.
We had a baby in nov 2012 and I today I decided to fit a dimmer in our little girls room so as not to wake her with bright light when its time for a bum change in the middle of the night.
Ive changed plug sockets around the home and my parents home since I was young mainly first by copying how it was originally wired up and now by the same way but using more common sence. But this light switch has really baffled me (The house is a vic hallam and was built in the 60s) normally im use to red and black wires but this had 3 red wires, 2 of which were wound together and 2 black wires which were bound together with a yellow rubber plug thing (kind of like a thimble you use when sewing).
The 2 bound red wires and single red wire were wired into the light switch.
The switch its self had no visible markings to follow so I decided to use my judgement and wired up the dimmer the only way I could see. The dimmer had 3 holes L1, L2 and com. The com had no ability to connect anything leaving me with L1 and L2 so I wired it up with my red wires and turned the mains box back on and the light seems to work fine. There is a slight buzz coming from the dimmer but I remember my old one in parent house doing the same thing.
So basically after my essay have I done it right and if not what do I do?
I have seen simler posts on here but they havent helped me in my particular case.
Thanks in advance.
Ry
Thanks in advance.
Ry
