Hi all,
I have some new taps to fit on a existing bathroom basin, unfortunetly the new (flexible) tails are slightly too short to connect to the isolating valves attached to my 15mm copper feed pipes!
I've been looking on screwfix/toolstation to identify some kind of suitable "extension" (only need perhaps 5cm+) which will connect either between the 15mm copper pipe and the compression fitting on the isolating valve or between the valve and the flexible tap tail but can't find anything
Can anyone recommend a solution (preferably using compression fittings...)? I was hoping to find something like this but with a female connection on one end...
Can anyone help with suggestions?
