I realise (through searches) this is a fairly common fault and often the culprit is the expansion vessel but on searching for mine i stumbled across what might be causing the issue. Overnight the boiler often loses pressure so that the heating wont come on in the morning as follows
No pressure left
I took the front off to see if i could see he expanison vessell but no joy
However while checking the side i noticed there is a leak - i assume this must be the cause
So :-
a) Would you agree
b) How would i tighten this if possible ?
I'm hoping the part doesnt need replacing.
Thanks in advance,
Mike.
No pressure left
So :-
a) Would you agree
Thanks in advance,
Mike.
