Removing emulsion painted on top of gloss
3 Feb 2013
London
About a year ago we had a professional painter paint three rooms for us. He put emulsion on the woodwork, painting directly onto gloss paint without any preparation except for sugarsoaping it. Now paint is flaking off where ever it gets bashed.
What is the best thing to do about it? From internet research it looks like we need to get all the emulsion off, abrade the surface and then repaint with an oil based paint.
Is this right? And how do we get the paint off? We have a lot of surface area to deal with - skirting boards, doors and door frames and also a wooden floor. Tips very much appreciated!
Try scraping the emulsion off with a scraper or a even a wood chisel first.
Thanks Sparkwright. I was hoping there'd be an easier solution! Also, the doors are just plain board so I'm worried it won't work or I'll damage them. Apparently the paint underneath is eggshell, not gloss - might make it a bit harder too?
Sanding should be sufficient to break through the emulsion and get back to a decent surface. Unless it's particularly thick emulsion won't stand up to sanding very long.
No pro painter would emulsion woodwork.
What is Quick Drying Wood Primer Undercoat ??
Just a modern/posh name for a thicker type of Emulsion !
Give it a sand and if unsure what previous paint was on there then use an oil based undercoat
About a year ago we had a professional painter paint three rooms for us. He put emulsion on the woodwork, painting directly onto gloss paint without any preparation except for sugarsoaping it. !
are you sure it was emulsion ,not the acrylic undercoat mentioned :wink: anyway s/soap is no substitute for glasspaper - the lack of glasspapering ( sanding) is the problem - get a little palm sander , some 80 grade glasspaper , connect a henry hoover to the sander ( or even have someone keep the nozzle near the sander ) job `s a good un.
