Hello all,
We have a Zanussi condensing tumble dryer which has started tripping the RCD on the fuse board. Not the MCB for the utility room plugs.
It trips when the dial is turned from the stop position but before the start button is pressed, which I thought was strange.
It's not the sockets, and the plug is a sealed one.
Any thoughts on what it might be? We can ill afford a replacement right now so if can be repaired without much expense that's the preferred option.
Thank you.
Thank you.
