Zanussi tumble dryer tripping RCD
5 Nov 2009
West Midlands
Hello all,
We have a Zanussi condensing tumble dryer which has started tripping the RCD on the fuse board. Not the MCB for the utility room plugs.
It trips when the dial is turned from the stop position but before the start button is pressed, which I thought was strange.
It's not the sockets, and the plug is a sealed one.
Any thoughts on what it might be? We can ill afford a replacement right now so if can be repaired without much expense that's the preferred option.
Thank you.
JohnD
Do you accept rounds of applause?
15 Nov 2005
South
Cook Islands
earth leakages are most common on watery appliances. Start by looking for a water leak inside.
if the drier is in a cold place, it might be getting condensation inside.
5 Nov 2009
West Midlands
Thanks John.
It was moved shortly before this problem showed. I think water might have moved inside and caused the fault. If we dry it out (hairdryer?) for a while is it likely to work again or will it most likely have fried something?
JohnD
15 Nov 2005
South
Cook Islands
if it is tripping the RCD, there is a good chance the power was cut before causing damage.
29 Apr 2008
Croatia
It might need a good clean out. If there is a build up of lint and that gets wet from water sloshing about inside it will retain the dampness and be hard to dry out.
5 Nov 2009
West Midlands
True. It's not easy to clean out without taking the whole thing to bits sadly. Maybe I'll give that a go tomorrow.
29 Apr 2008
Croatia
The most important area to keep clean is around the heating element and that is also the most likely area that is causing the RCD tripping.
5 Nov 2009
West Midlands
This is what I've done, and it seems to have been successful! Fingers crossed it lasts.
Many thanks for your input folks.
