My system was working fine until last week then i started hearing loud noises every so often coming from the pipes above the bolier.
So i went in the loft and checked the little water tank and the top layer of the tank was covered in slime ( guessing this isn't normal !) So i removed all the slime and turned the bolier on again. No noise and it worked perfectly...
However today the noises have returned and now when i turn on the heating the bolier light only stays on for about 30 seconds and then switches off. I think the problem is air in the pump but this is a newish pump (grundfos alpha2) / bolier installed in 2010 and i cannot find the air valve on / near the pump to see if i can release any air
I have attached a few pictures one of the pictures ( picture 2 ) i think is the pump air valve but no matter how hard i try to turn it doesn't move!
Anyone got any ideas?
Many thanks
Many thanks
