    Dismiss Notice
Is Pressurised tank for heating system correct
Discussion in 'Plumbing and Central Heating' started by markyuk, 17 Jul 2017.
  1. markyuk
    markyuk
    10 Jan 2012
    55
    Thanks Received:
    2
    Kent
    Country:
    Hello
    I have a question regarding a pressurised tank in my central heating system.
    So the system is a normally system bolier with hot water tank and cold water tank.
    It is a pressurised system so on feed tank for CH.
    The question is where does the pressurised tank go in the system.
    At the moment it is in the feed from the 3 way valve to the rads is that right . As I have seen them fitted between the bolier and the pump .
    Just asking the question as just moved in to the house and just double checking every thing Is right.
    Thanks for the help.
    Mark
  2. scatmanjohn
    scatmanjohn
    2 Nov 2005
    3,391
    Thanks Received:
    237
    Country:
    Your description is a bit confusing. When you say pressurised, do you mean the system is filled via a filling loop and there is a pressure gauge for you to see how much pressure is in the system?
  3. Sponsored Links
  4. markyuk
    markyuk
    10 Jan 2012
    55
    Thanks Received:
    2
    Kent
    Country:
    Sorry yes that's it the red tank with a filling loop.
  5. scatmanjohn
    scatmanjohn
    2 Nov 2005
    3,391
    Thanks Received:
    237
    Country:
    In that case,it's fine where it is.
  6. Sponsored Links
  7. markyuk
    markyuk
    10 Jan 2012
    55
    Thanks Received:
    2
    Kent
    Country:
    Ok thanks just thought I check thanks very much
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
