Replacing Honeywell thermostat
22 Mar 2011
Kent
Hi all,
I'm in the process of decorating and would like to replace my heating thermostat as the housing is cracked and it looks a bit unsightly. I would like a digital one if possible. Could anybody recommend a direct swap for it? The model number is T6360B and there are four wires going to the terminals inside which I've posted a picture of.
Hope you can help.
Regards
Adam
Hi Whitespirit,
Thanks for the reply.
I like the second option. It says in the description 2 wire connection. Will it still be ok as mine has 4 wires?
Regards
Adam
Hi Adam
Your current stat has L, switched L, N and Earth. The new stat runs on batteries, so doesn't need all the wires. You will just use your L and swiched L.
The other two should have the bare ends made safe and tucked out of the way inside the stats mounting box.
Thanks again.
I've just ordered it. Doesn't it need an earth either? Which other wire don't I need from the picture I've posted in my album?
Adam
I'd have gone for the CM907. Well, I did go for the CM907. I replaced my 6360 with one a few months ago.
Easy-peasy swap with a little help from the guys on here.
Thanks again.
Adam
No Earth and Neutral required. Common and switch are all you need. Make safe in the wiring centre as well as the stat - it takes all of 2 minutes as its not good practise to just blank them behind the stat.
Hi
Received my new thermostat. The terminals are: A x B y C. Can somebody look at my picture in my folders and tell me which two wires need to go in which two terminals and which two I need to make safe?
Regards
Adam
Hi Whitespirit
Yes that's the one I bought. Thanks a lot. Shall I just make the other two wires safe?
Adam
Yes. If you can, it's also best to disconnect these 2 wires at the other end too. More than likely it will be in the wiring centre/junction box.
