cable confusion
22 Aug 2004
Hi experts
I've got a laptop with a VGA port but my TV has DVI, HDMI, scart and component (I've looked this up - I don't know these things) and I want to connect said laptop to TV - which is the best route to take in terms of cost and picture quality?
Many thanks in advance
Steve
In simple terms ... you cant!
None of those inputs you have mentioned can accept the VGA output from the laptop directly via a simple cable. There are black box convertors on the market which will change the format for you but these can be expensive.
Are you sure there isnt a VGA port lurking on the TV somewhere?
Adrian - checked again there's definitely no VGA on the TV. There are some other mysterious slots (to me at least):
Digital Audio Out (optical)
LAN
A USB port
Common Interface
I've also noticed that the HDMI label actually refers to 2 ports labelled 1 and 2 with the 1 then labelled DVI so is DVI the same as HDMI?
Jackrae, thanks for the link although some of the reviewers had trouble with that cable and I assume that this converter doesn't come with the required cables to connect up?
Cheers
Steve
Just buy a vga to dvi converter
imgres
[That is not what those do.]
Although.... if the DVI input port on the TV is DVI-I (the OP would have to look it up in the manual), then that adaptor (not a converter!) might well work...
I also doubt is is, but theres always one in a million chance...?
Are sure the laptop not have DVI/HDMI quite a lot have a dual hdmi/usb port.
Otherwise its either a vga-dvi/hdmi converter, or a usb to dvi/hdmi adapter. Or a new laptop, or TV.
For ref, dvi and hdmi are basically the same interfact in a diffrent connector, with hdmi including audio.
Daniel
