Hi there. I hope someone here can help.
My parents have an oil fired boiler controlled by a Hostmann H27XL programmer a Sunvic SA2452 cylinder stat and a Honeywell V4073A 3 port valve. There is no room stat - all the rads have thermostatic vales. Recently the pump was replaced and, possibly coincidently, things no longer work as they should. Basically the pump and boiler only fire when the cylinder stat is calling for heat. As soon as the stat reaches temperature the HW and CH both go off. Previously it was possible for the CH to work regardless of whether HW was calling for heat or not.
I have had a look at the wiring and it all looks correct and connectivity looks correct (bearing in mind absence of room stat)
I do not fully understand the motorised valve function - I understand it open either or both HW & CH circuits but does it also turn pump & boier on? If so is it likely this has failed?
Many thanks in advance
