I'm looking to replace my current bathroom light, wires are - 2 pairs for circuit, 1 for switch, and bathroom fan (two wires plus earth).
At present they go into a rose which is in the bathroom side of the ceiling, The new light fitting comes with just a choc block for L N and E, so i need to move/remove the rose into the attic space above.
So I assume best practice is to use a Junction Box in the ceiling and pass down just the switched live, neutral and earth.
Any recommendations for what junction box to put in? Was looking at this:
http://www.screwfix.com/p/crabtree-4-terminal-20a-junction-box/70677
Screw it side ways onto the nearest joist where wire run is practice, and shift insulation away from the wires... anything else i should do as part of the change?
(besides isolation, checking its dead, checking its wired correctly, checking connections are remade correctly, continuity is maintained etc)
