i would opt for screws for the floor to allow alterations and replacement easier same with the cladding
i used a mixture off nails and screws [4" 3.5" 100mm and 90mm ]on the frames
basically though i had loads but finished up raiding the 10x3.5" after running out off nails and larger screws
That's a good plan, I'll switch them out for screws then. Forgot to add the cladding in that previous post, I'll do one with the OSB walls, cladding and fixings later on. Hopefully be able to get a rough costing for this tomorrow.
I work at a DIY shop so I get colleague discount and we can price match anything local so I can pick and choose everything myself. I'll check for the pressure treatment though.
