I have a 1921 built end terrace house, with a solid brick wall (LBC Rustic brick) no cavity.
I cannot find the DPC! I have scratched away at the pointing in a few different places from ground level to two bricks above floor level - nothing!
The house has no damp there are no external tell-tale plug holes indicating that a chemical DPC has been used so there must be something, shouldn't there?
What is equally odd is that the shared alley - concrete - between me and next door is almost 3 bricks higher than our floor level. Along that alley our house wall has a skin of render, about 10mm thick, and 3 courses high. This rendered 'skirt' is only down the side not at the front or back.
We're on a bit of a hill so the house next to us is 2 maybe 3 courses higher than ours and they had an extension put up where it can be seen that their new DPC is tied into the old brickwork at the same level as the top of their rendered skirt. If that is the same with my house, it would mean the DPC is 6 courses above the floor! Surely incorrect!
My problem is, I am going to be building a short walk that will butt upto the house so need to locate the DPC link in with the walls DPC.
Any ideas as to what I can / should do?
